Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: IF you need to break a window to get into your Passat B6/7 Wagon don't break the rear
    Dec 2007
    ivanhoe vic
    Quarters.
    Keys locked inside a bag in the back of the car - car was deadlocked so no way to unlock RACV unable to gain entry. Advised to break the right rear quarter to gain access... $854 later.. Advice is to break driver's or passenger window lot cheaper to replace.
    BTW can the dead lock be turned off via VAGCOM? The scary part is if you lock yoursel inside the car without your keys, you can't get out as the door handle or unlock buttons will not allow you to open the doors.
    I know there is a release lever inside the warning triagle in the back tailgate but this only works if the battery or locking mechanism has failed. I'm going to buy one of those small glass hammers.
    B6 Passat Wagon No KESSY
    Apr 2010
    For the Mk6 Golf (2009+, don't know about older ones), if you press Lock on your fob once, the deadlocks are used, but if you press the lock button twice, the car locks without the deadbolts (so people inside can get out).
    I don't know of any VCDS settings for this.
    Aug 2012
    Perth WA
    Same with B7 Passats
    Jul 2010
    Robina Gold Coast
    Does the car have a hidden door lock on the drivers door ,there's a slot to prize the cover off? If you have a spare key at home ?
    If that's not available you might have to break the tail light to gain entry to the boot.
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by OilBurna View Post
    Same problem on the Toyota Kluger
    I think as a general rule, never break little windows that don't open...
    (The right rear quarter window of the Octavia has a TMC antenna etched into it)
    Pacific Paradise QLD
    Quote Originally Posted by ian View Post
    Wont get into the boot of a Passat (B7 Anyway)through a Taillight Thats for sure.
    IF you have a spare key at home you would be able to unlock it with the remote as the remote is the key. IF you PRISE the little cover off you wont get a PRIZE as you will probably wreck it and anyway you need the key that slides into the remote to open it
    May 2010
    Melbourne, VIC
    How would that even be possible without doing something silly though? The deadlocks only operate with the remote - the lock button inside the car doesn't engage the door locks (it doesn't even work when the door is open).
    The only possible way I can see to deadlock yourself in is if you pressed the lock button on the key with a door open, then left the key outside, got in, and shut the door.
    Quote Originally Posted by Amalgam View Post
    And the B6 Passats too.
    So far as I can tell, pressing the lock button once locks the doors immediately with deadlock. Pressing the lock button again within about two seconds will then disengage the deadlock.
    Dec 2007
    ivanhoe vic
    Yes thanks for the tips guys common sense should have prevailed should have broken the drivers or front passenger windows much easier to replace racv guy was telling me it would be more expensive to replace door windows as the door has to be pulled apart ...
    Only takes 20 mins to strip inside of door a bit longer to take the inner skin off as it has rivets holding it on.
    Had one of mine apart for a rattle but didnt go right in as I found it before having to go that far
    Jul 2007
    Brissy
    Break the widescreen, my insurance covers this with no excess.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
