very easy.
1) Put the ignition on but dont turn on the engine and make sure the gear is in "Park" position
2) adjust your seat and mirror to your desired position
3) Press the set button then number (eg. "1") until you hear the "gong"
4) Put gear to "Reverse"
5) adjust your passenger side mirror so that you can see the kerb. (kerb function).
6) after that hold the number "1" again until you hear the "gong"
7) put the gear to "P"
take the key out and press "unlock" to unlock the car using the remote
9) put the key back then press the number "1" again until you hear the gong
10) Now the seat/mirror should be programmed to the key.
11) Repeat the above steps for your second key for alternative seat setting.
Now when you unlock the car with key 1, the seat/mirror setting will automatically adjust to setting no.1 whereas if you unlock the car with key 2, the setting will change to setting no.2 automatically. Also when you put on reverse, the passenger side mirror will dip to see the kerb (only if you have the mirror button point to your left hand side mirror, if you have the button point to middle or RHS mirror, the mirror wont dip) Hope this help.
