Results 1 to 8 of 8
Thread: How safe are spacers?
    Aug 2008
    Elliminyt
    I am fitting RS4 19" rims to my R36 wagon when it arrives in a few weeks. I am also considering using spacers. How safe are they? Will it still be covered for insurance?
    Jan 2008
    Melbun
    Quote Originally Posted by Macka View Post
    get hub centric spacers so there isnt any more load put on the wheel nuts in ways they shouldnt have load.
    just wondering though, why do you need spacers on such wide rims? you need high offset on a passat...
    2x Caddy, 1x Ducato
    Sep 2007
    most proper spacers you buy here have tüv approval. which is pretty much a european standard. except they're illegal here
    edit: unless they're engineered?
    87' MK2 GTI
    13' MK7 TDI
    Aug 2008
    Elliminyt
    Quote Originally Posted by Mischa View Post
    Mischa,
    You will need to excuse my ignorance on this subject. I am trying to ensure that the wheel fills out the guards and sit right to the out edge like say an RS4 or M3. I was think of putting 245's all round rather than the 235's that come standard. Am l on the wrong track with my thoughts? Also if insurance is going to be an issue l wouldn't do it anyway.
    Jan 2008
    Melbun
    Mischa,
    yep you're on the right track. however if you buy wheels that are say; 8.5" wide with an offset of 50, that will most probably fill out the guards (although i dont own a passat, so you'll have to check the clearances yourself). 245's would be the correct fit on 8.5" wheels. however if you buy 7 or 7.5" wide wheels with an offset of 50, you might want to get spacers to lower the offset and push them out a bit more. feel free to check back here with wheel specs if you're unsure
    2x Caddy, 1x Ducato
    Aug 2008
    Elliminyt
    Thanks very much. The wheels are as follows:
    19x 8.5" 5/112 with offset of 45. The original rims on the R36 are 18x8 5/112 with 44 offset and run a 18x235x40. So would that mean with an extra .5" wide rim and and running a 19x245 35 would fill out the guard more?
    Jan 2008
    Melbun
    if i were to guess i'd say 8.5" with offset 45 would fill out the guards fairly well, especially in 19". on my golf i have 8.5" wide with offset 50 and i'm running 225 tyres which are slightly stretched on the rim. see the picture below. yes 245's are the correct width but it depends if you like the stretched tyre look or not; personally i do come to think of it, the wheels you're talking about would look really really good on a passat, DO IT
    225/45 tyres on 8.5" wide rim:
    2x Caddy, 1x Ducato
    Aug 2008
    Elliminyt
    Yep l will do it. Am ordering the RS4 rims and tyres this morning. Have finally decided to fit Yokohama V103. Wanted the Michelin PS2 but couldn't justify the price. I will post pictures once R36 arrives in early December. Thanks for your help.
