Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: how to open door manually
    Feb 2007
    sydney
    Hi Guys,
    I disconnected my car baterry on passat my08.. I couldn't opened my door car.. any one got any idea or got the same experience like this before?
    How do you solve this?
    thanks
    origin
    Sep 2008
    Thumbs up
    Fairly simple process, as shown in the manual (but if it's locked in the car..)
    1) Remove the spare key from the main key.
    2) Undo the cover flap at the rear of a front door handle (there's a slot in the under side of it).
    3) Door unlock barrel now exposed, use spare key to manually unlock door. Looks like the same sort of key slot as used on Commodores, Golfs, etc.
    Cheers..
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
    Feb 2009
    Quote Originally Posted by passatpout View Post
    Cheers..
    Note too that if you have the VW car alarm fitted this will set it off... but pushing the remote into the ignition slot will de-activate it.
    Feb 2008
    Sydney, Australia
    Quote Originally Posted by Swallowtail View Post
    Or by pressing the key fob door unlock button.
    Feb 2009
    Quote Originally Posted by Lance B View Post
    True... but I figured that if you need to be manually unlocking the car that the most likely reason is that the key fob is inoperative... as I missed that the reason the OP posted was cos he disconnected his battery!
    Feb 2007
    sydney
    Hi Guys,
    passatpout, swallowtail and lanceb thank you for your respond.
    My mistaken I disconnected the battery while the car in locked.
    I am going on vacations for 3 months.. I tried that by using the spare key
    to unlock it on driver door but no luck. It is a electric lock.
    Maybe some one got any idea how to open the bonnet manually so I can connect the battery.
    or
    any other idea??
    thanks again for all your respond
    origin
    Sep 2008
    Sorry, should have made it clearer - not the spare key as in the second key for the car, but the removable key within the electronic keys, which looks like a plastic version of any profile cut key used for the last 20-odd years. Under the flap on the door is a manual lock barrel.
    If you're still having trouble, I'll have a crack with mine tonight (it's an MY08 as well) and photo each stage.
    Otherwise, for a manual release of the bonnet, have a look under the bumper and see if the release cable is accessible.
    Feb 2007
    sydney
    Hi passatpout,
    Thank you for your help.
    I tried both plastic key or spare key. I have no luck so far with driver door.
    Yes please if you got time. Could you try it on your MY08 please? But don't lock your bonnet after disconnected battery.
    Thanks again
    Regards
    origin
    Sep 2008
    OK, I'll have a crack at it, as soon as the State of Origin is finished..
    Mar 2009
    The state of origin is finished. Chop chop.
    2007 R32 5Door DSG Blue
