Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
Thread: how to open door manually
  1. #51
    Jun 2009
    yep, the cable under the car to the starter motor is the go, this is what the RACQ did to my car when the battery died after I hadn't driven it for a couple of months.
    Gone...........R36 Icelandic Gray Wagon
    Specialising in off-topic discussion
  2. #52
    Feb 2008
    Outer East - Melbourne
    I Guess the OP has given up or solved their problem by putting a brick thru a window...
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
  3. #53
    Feb 2008
    Just for a laugh, I tried the "pop the cover off the door handle" entry method and it does work but the locks are definitely electric so a disconnected battery will be a show stopper!
    I did note that if you unlock the doors this way the red LED on the door continues to flash so I assume the immobiliser is still active.
  4. #54
    Jan 2008
    Quote Originally Posted by richdave View Post
    The immobiliser is deactivated by inserting the keyfob (or on other models inserting the key into the ignition) and as the car starts a transponder is powered up in the key that authenticates and a new code is written. If this process fails the car will stop a few seconds later and display a warning.
    http://www.my-gti.com/392/volkswagen...nd-transmitter
  5. #55
    Feb 2008
    So did the OP ever et this problem sorted??
