Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: how to open door manually
  1. #21
    Dec 2008
    Are the MY08's different to the 09 ?'s The battery for the R36 is in the boot behind the panel that slides off in my Wagon ?
  2. #22
    Jun 2009
    Wink
    Quote Originally Posted by bennobee View Post
    Same for MY09...
    Gone...........R36 Icelandic Gray Wagon
    Specialising in off-topic discussion
  3. #23
    Jan 2008
    Quote Originally Posted by Swallowtail View Post
    Note too that if you have the VW car alarm fitted this will set it off... but pushing the remote into the ignition slot will de-activate it.
    You can alter this using Vagcom/VCDS to disarm the alarm when a key is used to unlock and/or arm the alarm when a key is used to lock. By default these are disabled.
  4. #24
    Feb 2007
    sydney
    Hi Guys,
    After 1 week of discussion with vw road assist. No luck.. they suggested to brick my window...
    I was thinking to cut my sunroof rubber if possible.. since rubber is cheaper than window glass.
    Any other ??
    maybe cut my front grilll..??
    thanks
    origin
  5. #25
    Sep 2008
    Is there a way to get under the bonnet and pull the cable from under/behind the bumper?
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
  6. #26
    Feb 2007
    sydney
    Hi Passatpout,
    Could you possible to check where is the cable going exactly?
    Thanks
    origin
  7. #27
    Canberra
    If you ever need to smash glass to get into your vehicle check availability and price before smashing. The front windscreen is often the best option as they are replaced far more frequently than any other (and so are more available and cheaper than the others)
  8. #28
    Sep 2008
    Quote Originally Posted by origin View Post
    Hi Passatpout,
    Thanks
    origin
    in short, without being rude, no, the suggestion was for you to have a look.
  9. #29
    Jun 2009
    Tamworth, NSW
    I find it hard to believe that a car would be manufactured without a fail-safe for the door locks/electrics.
    From the previous posts I assume that you have tried the plastic key as per the manual.
    This kind of highlights that possibly VWAssist isnt all that good either
    Rich
    MY08 TDi 125KW Black Leather, Deep Black Pearl
  10. #30
    Apr 2009
    Melbourne, VIC
    errrrr... the steps with pictures above works perfectly. you must not be doing it right.
