Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: how to open door manually
    Apr 2009
    Melbourne, VIC
    The instructions given work fine for me on my MY09.
    Sep 2008
    Here goes.. with photos... first Photobucket attempt.. so be patient.. (can anyone help getting the photos in there??)
    1) Take your key and remove the inner plastic key.
    2) Find the slot in the underside of the rear cover panel behind the driver's door handle.
    3) Use the plastic car key (or small screwdriver) to flick the cover off. This may go flying, since it's held on fairly tightly with plastic clips, and when it comes off will go suddenly. This will expose a manual unlocking key slot and barrel.
    5) Insert plastic key into slot and rotate 90 degrees clockwise. There is a resistance at about the 80 degree position, which must be pushed through to mechanically unlock the door.
    Hope this helps, otherwise call VW Assist.
    Last edited by passatpout; 17-07-2009 at 07:03 PM. Reason: Tried to get photos inline... :(
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
    May 2009
    Just fixed the image tags
    Pete
    MY13 Octavia vRS TDI DSG
    Sep 2008
    Quote Originally Posted by Pana View Post
    Thanks.. what link do they need to be or how were they fixed?
    Cheers..
    Apr 2009
    Melbourne, VIC
    Quote Originally Posted by passatpout View Post
    Cheers..
    add [ IMG ] to the front of any image link and [ / IMG ] to the end and it embeds it (without spaces though).
    Photobucket has this as an option ready to copy and paste for every image you upload.
    Sep 2008
    Quote Originally Posted by Rocket36 View Post
    Yeah, that's what I tried (the [ img] and [ / img] without the spaces) and all it put in the post was the link.. I took the link from the address bar in Explorer. Will keep looking in Photobucket..
    Feb 2007
    sydney
    Hi Rocket36 / passatpout,
    Thank you for your help and image..
    I did that but no luck.
    Did you unplug your car battery before you tried that?
    Thanks
    origin
    Apr 2009
    Melbourne, VIC
    The link on it's own is: http://i624.photobucket.com/albums/t...g/DSC00268.jpg
    With the code: [ img ]http://i624.photobucket.com/albums/tt321/alpout/Passat%20Manual%20Unlocking/DSC00268.jpg[ /img ]
    With the code but without the spaces:
    Trust me - it works... It works for any image link on the internet!
    Sep 2008
    Quote Originally Posted by origin View Post
    Thanks
    origin
    Nope, I left my battery connected.
    Might be time to call VW about it... it should still have roadside assistance available..
    Sep 2008
    Ah-hah.. thanks Rocket, all done now, I think I can work it out from here..
