Are the MY08's different to the 09 ?'s The battery for the R36 is in the boot behind the panel that slides off in my Wagon ?
Hi Guys,
After 1 week of discussion with vw road assist. No luck.. they suggested to brick my window...
I was thinking to cut my sunroof rubber if possible.. since rubber is cheaper than window glass.
Any other ??![]()
maybe cut my front grilll..??
thanks
origin
Is there a way to get under the bonnet and pull the cable from under/behind the bumper?
MY08 Passat 2.0 TDI Wagon
Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
Hi Passatpout,
Could you possible to check where is the cable going exactly?
Thanks
origin
If you ever need to smash glass to get into your vehicle check availability and price before smashing. The front windscreen is often the best option as they are replaced far more frequently than any other (and so are more available and cheaper than the others)
I find it hard to believe that a car would be manufactured without a fail-safe for the door locks/electrics.
From the previous posts I assume that you have tried the plastic key as per the manual.
This kind of highlights that possibly VWAssist isnt all that good either
Rich
MY08 TDi 125KW Black Leather, Deep Black Pearl
errrrr... the steps with pictures above works perfectly. you must not be doing it right.
