Here goes.. with photos... first Photobucket attempt.. so be patient.. (can anyone help getting the photos in there??)
1) Take your key and remove the inner plastic key.
2) Find the slot in the underside of the rear cover panel behind the driver's door handle.
3) Use the plastic car key (or small screwdriver) to flick the cover off. This may go flying, since it's held on fairly tightly with plastic clips, and when it comes off will go suddenly. This will expose a manual unlocking key slot and barrel.
5) Insert plastic key into slot and rotate 90 degrees clockwise. There is a resistance at about the 80 degree position, which must be pushed through to mechanically unlock the door.
Hope this helps, otherwise call VW Assist.
