Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: how much boost for chipped?
    Aug 2006
    hey jst revcieved my ecu i bought. its chipped, but cant put it in til weekends..
    jst want to know before hand what psi it should be at so i know i'm running fine and no problems.. and is it that psi every gear wen i plant it..
    Mar 2007
    sydney
    Quote Originally Posted by 1DUB2C View Post
    about 14psi or above
    which chip did you buy, where from and how much?
    The majority of chips range from 0.8-1.0bar (11.6-14.5) from what I can figure out.
    Sleepy Guest
    i think it runs at 14.5 from memory....
    Jul 2007
    Sydney - the regressing city
    think the amount of boost also depends on what other mods u have...
    my wett chip can hold 1.4 bar quite easily, but i'm running a K04 and EBC...
    Aug 2006
    you have a passat??????????? with k04?
    Aug 2006
    just another question...
    could i use my manual boost controller instead of the n75 with a chipped car? because on my stock, with mbc i feel the jolt of power kick in where the n75 is like smooth.
    Jul 2007
    yup - should be bringing it with me when i move down under towards the end of this month...
    Jul 2007
    iirc, the mbc works in conjuction with the N75 and will help increase the boost pressure.
    although i know a few who have gone this route, it is generally not recommended as the mbc settings are "hit or miss" type.
    an alternative would be to change the N75 to one with a more aggressive setting...
    Mar 2007
    sydney
    running 14.5psi std golf gti, chipped
