Battery draining overnight
Hi,
Has anyone experienced this with their Passat before? I have a 2006 TDI 105kW Passat Wagon. Had a new Varta N22 battery fitted 18 months ago and now find the battery drains overnight.
I charged it overnight the next evening, then drove it during the following day - no probs. Then left it overnight and next morning it was flat again.
There are no obvious cabin lights on or otherwise as far as I can tell. Either the battery must be faulty or there is a short somewhere in the wiring. Any ideas for efficient diagnosis?
Can I disconnect this battery overnight without causing problems to the electronic management system in the vehicle?
Any assistance appreciated.
Cheers,
FG
- You may not post replies
- You may not edit your posts
Forum Rules
