Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: How far on front brake pads?
    Dec 2007
    ivanhoe vic
    Up to 74,000km just had inspected and reckon still good for another 8-10,000km. Had rears done already 2007 tdi truckster.
    B6 Passat Wagon No KESSY
    Erskineville, NSW
    113,000km on my Octavia (which is like a tiny Passat or a fat Golf) - fronts still at 6mm so they are good for another 100,000km or so.
    Rears are down to 3mm & will need replacement this year sometime (rears come on before fronts to minimise nose dive).
    Sep 2011
    Melbourne,Vic
    Just had my 30,000 klm service & was told both front discs & pads will need replacing at the 45,000 klm service. I was a bit surprised given I drive exactly the same roads & conditions as my previous cars. Might have to check them for myself.
    MY12.5 B7 V6 Passat wagon in Mocca Anthricite with Panoramic sunroof, SatNav, Driver Assistance & Visibility Package, Adaptive Cruise, Park Assist 2, Auto Tailgate,Tint, Towbar & RVC
    Erskineville, NSW
    Quote Originally Posted by MJW View Post
    not unusual to be due by 45,000km. depends totally on traffic conditions & driving style
    Sep 2011
    Melbourne,Vic
    Thanks Brad. I drive in 30% peak hour & 70% free flowing traffic. To provide an indication of driving style, my original tyres are still on the car & based on wear I would get around 40,000 klms from the set. My Mazda 6 MPS only had front pads changed (not discs) at 80,000 klms. I know there is a lot to consider with weight, brands etc but just surprised is all.
    Erskineville, NSW
    Pads (and rotors) on Euro cars are generally quite soft (and dusty) compared to Asian machinery. Something to do with different philosophies on braking performance.
    Most dealerships are quite conservative about giving an estimate of remaining life because customers go absolutely birko if they run out of brakes between services. Lets face it, if you get to 45k & don't need them you'll be happy. Get to 45k & they tell you you are up for $450 in brake work & haven't prepared you & you'll be annoyed.
    Look on the bright side - gives you plenty of time to price some less dusty & more durable aftermarket stuff like REMSA.
    Sep 2011
    Melbourne,Vic
    Thanks again Brad. Agree whole heartedly re the difference between Euro & Japan. Happy to cop it given this is the standard. Also appreciate the suggestion on pads. Without comprimising braking to any great extent I would love to get pads with less dust.
    Jul 2010
    Robina Gold Coast
    At my 60,000km service my fronts were still 60% but my rears were down to40% ,It all depends on how you use your brakes?
    Sep 2011
    Melbourne,Vic
    Quote Originally Posted by ian View Post
    Ian, what sort of car do you drive? Are they OEM pads/rotors? I engine brake as well to balance out the load & progressively brake unless something onforeseen happens (rare). Based on current wear, the only way I would get your sort of wear was by not using the pedal at all
    Jan 2012
    Carnegie
    Is there a DIY link to change brake pads for a B6?
    My MFD tells me i need to check my pad so i'm guessing they'll need changing.
    2006 B6 Passat Wagon 2.0 TDI
    RCD510, MDI, 9w7 bluetooth, Footwell lights, Door warning lights
    VAGCOM cable owner
