I'm so glad that you have raised this thread.
Can I ask, is the actual boot handle with the lowline camera integrated any different to the original boot handle considering you have a power tail gate? I have a power tail gate and was wondering if it is any different. I.e. there is a sort of button feel in the handle for it to engage the boot to open.
Cheers,
Damo
Sent from my HTC_PN071 using Tapatalk
2010 .:R36 Wagon - Biscay Blue
RNS510 | SatNav | DynAudio | MDI | 9W7 Bluetooth | Sunroof | Power Tailgate | Factory Tint
TBC - Lowline RVC
The integrated camera boot handle works in exactly the same way as before - it has a similar grip.
I emailed JKU who advised that the cameras are different between highline and lowline. JKU quotes the part number for the highline camera as 5NO827566D. Not sure what the part number is for the lowline version.
It looks like going highline would cost at least twice as much as doing a lowline camera retrofit. I wouldn't mind seeing how a highline camera works in real life though. However I'm beginning to realise that it probably isn't really worth the effort, especially if I need to buy another camera...
probably the better choice mate considering you already have the camera. Do you really wanna muck around near that hinge area again? Me thinks not!!![]()
Thanks to both Passat R36 and prn31!
TBC - Lowline RVC
Mine was a dealer fit not an original VW part and it comes on when I select reverse, but if I select drive and then reverse again (ie. three point turn) the camera won't come back on again unless I hit the parking sensor button to turn OPS off and then go drive reverse again. It seems like OPS overrides the camera. It also throws codes in VCDS but it all works fine other than that so I have to either ignore the codes or remove the camera. I put up with the codes.
If I were the original owner I'd have made the dealer fix the install or undo/refund but as I'm the second owner I deal with it.![]()
