Results 1 to 10 of 15
Thread: High grip tyres for Passat TDI.
    May 2010
    vic
    I noticed my tyres chirping a lot when accelerating off fast from the lights.
    is there a way to improve this some how?
    I can ease off the throttle obviously but what's the point if I can't use all that torque??
    Any recommendations?
    Jun 2009
    Michelin Pilot Sport PS3's or Goodyear Eagle F1's are meant to be very grippy but cost a bit and will wear quicker.
    If you are trying to use the torque then you shouldn't be reving it and giving it a bootfull at the lights as the torque band in the diesel's is short and quite low down in the rev range.
    May 2010
    vic
    Quote Originally Posted by team_v View Post
    Thanks for the quick reply and great advice I'll give Goodyear Eagle F1 a go not too bad at $200 each.
    Feb 2008
    You're welcome to the Goodyears Eagle F1 Assymetrics sitting in my shed, they only have around 12,000 kms on them.
    Should never have strayed from the Michelin PS2's, and am glad I now run PS3's.
    Jan 2008
    Canning Vale, Perth, WA
    Cro, youre quite rare in that statement, the rest of the world loves the Goodyears (especially in the wet) including virtually every independent tyre test Ive read, what did you manage to do to get so out of favour with them?
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    May 2010
    vic
    Quote Originally Posted by Cro View Post
    Damn why do you have to live in Sydney? worst place for motoring...
    Jan 2008
    Sunshine Coast
    The Passat TDI has the peaky GT TDI's 125kw 350nm 2.0 engine. In stock form this has a massive torque spike at 2000 rpm, and whilst I love that, it certainly doesn't make for easy or tyre friendly driving. In the heavier Passat I've heard it's better, but I'm afraid it's part of the animal. I do know a retune of the ECU tends to smooth that spike out, and give a more all over whilst giving a more controlled drive. That's something I personally don't want, but for your case this may be an option. Obvioulsy there are warranty concerns there, and with a newer car I'd suggest looking at the top end tunes that are easily turned off and don't register on the ECU's flash counter, and make it obvious to VW that it's been retuned.
    Erskineville, NSW
    Quote Originally Posted by mebius9 View Post
    you don't want them. They'd be the old model directional F1 eagles. I think team V is talking about the F1 Assymetrics, which most people are fairly happy with.
    michelin PS2 or PS3 get great reports too.
    Both the Michelin & the Goodyear will be significantly more than $200.
    If you want cheap but good the kumho KU31 will give terrific bang for buck. You need to shop around as prices vary by about $50 a tyre. 235/45x17 can be had for about $125 f/b/v but I've been quoted as much as $190
    you haven't actually said what size/brand/model you are running at the moment.
    May 2010
    vic
    Oh I'm running Dunlop SP Sports 01 235/45R17 at the moment
    it's been absolutely terrible at the lights, wheel spin at 2nd gear and the front end bounces off the ground like basketball while at it.
    But it's actually fine during cornering I accidentally did 90km/h tight bend turn on Mt Dandenong and it carved through tarmac like ice skate.
    Feb 2008
    Quote Originally Posted by gareth_oau View Post
    Do a search on my posts regarding tyres, particulary ones relating to road trips.
    I've detailed all my experiences with Dunlop SP01, Michelin PS2, Goodyear Eagle F1 Assymetric, Michelin PS2 and Michelin PS3 which are the tyres I have gone through since buying the R36.
