Page 10 of 10 FirstFirst ... 8910
Results 91 to 98 of 98
Thread: Here we go guys R36 1/4 mile
  1. #91
    May 2009
    Quote Originally Posted by Rocket36 View Post
    Or is that the difference between a run on a hub dyno and a roller dyno?
    Hub Dyno will always read higher - dunno if it would be as much as 40kW higher though...
    Pete
    MY13 Octavia vRS TDI DSG
  2. #92
    Feb 2009
    Quote Originally Posted by Pana View Post
    It's not quite as simple as saying a hub dyno will always read more. There are pros and cons to both, but at the end of the day a properly calibrated hub dyno is also telling you KW at the wheels - the size of which is one of the parameters entered.
    The reason I got mine done was for a benchmark and base line, not to compare with roller dynos though - and because going back later it is far more likely that they can reproduce the same result with less variables.
    This is a useful page that discusses why hub dynos tend to read slightly higher. http://home.earthlink.net/~spchurch/id12.html As Pana says though, it shouldn't be 30KW higher...
  3. #93
    May 2009
    yeah - ignore the "always" in my post then
    Pete
  4. #94
    Oct 2009
    United Kingdom (UK!)
    Hey Guys. Went back today and pulled a 13.38s 1/4 mile - so the remap has clearly sped things up a bit.
    Not a fair test though, I think there was a little more improvement to be had. My pre-remap 13.66 was done on Shell V-Power 99RON fuel - but this time it wasn't as there wasn't any available locally.
    That and I have 12'500 miles of crap in the air-filter which isn't going to help things either!
    Still, pretty happy
    No lack of grip either. I suspect I could run with slightly higher than stock pressures to lower the rolling resistance without impacting on off-the-line grip.
    Robert Bentley
    Passat R36 Saloon
  5. #95
    Feb 2010
    Quote Originally Posted by RobBentley View Post
    Still, pretty happy
    Still 13.38 is nothing to sneeze at for a nearly stock car!
    What MPH did you run with that time?
  6. #96
    Feb 2009
    :-ppppppppp rub it in Rob.
    Well done, that's a good time.
  7. #97
    Oct 2009
    Quote Originally Posted by ccpl View Post
    103mph trap speed.
    Robert Bentley
    Passat R36 Saloon
  8. #98
    Oct 2009
    Hey Guys.
    Have uploaded a video of this weekends run: http://www.youtube.com/watch?v=0w3Fz3AfRVs
    I intend to go back soon with a Pipercross Panel filter and V-Power 99 in the tank. Maybe 2-3 psi more in the tyres too, as there where no traction issues. Also tempting is a DSG remap to up the launch control rpm once its available without posting the controller to HGP in Germany.
    You never know, with a tail wind I might get a 12.99 one day - but I doubt it..!!
    Robert Bentley
    Passat R36 Saloon
