Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 98
Thread: Here we go guys R36 1/4 mile
  1. #51
    Feb 2009
    Yes Rob's car was stock when it did 13.66.
  2. #52
    Oct 2009
    United Kingdom (UK!)
    Quote Originally Posted by Caddyman View Post
    Rob, was your car stock (no Mods)when you did the 13.6625 run??
    thanks
    Matthew
    Hi Matthew.
    Yes it was
    Cheers, Rob
    Robert Bentley
    Passat R36 Saloon
  3. #53
    Jul 2009
    Highlands NSW
    Quarter Mile Times
    Rob
    Were they imperial or metric seconds?
    You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
  4. #54
    Oct 2009
    Quote Originally Posted by Highlander View Post
    Rob
    Sorry - what?
    Whatever SantaPod run at.
    Robert Bentley
    Passat R36 Saloon
  5. #55
    Jul 2009
    Highlands NSW
    Perhaps you could ask them and let us know. Might explain how Aussie R36s can only manage low 14s at this stage.
  6. #56
    Oct 2009
    Having done some reading - I doubt its metric. Apparently the UK trailed it for 7 weeks in 1976 and gave up on it as a bad idea.
    Robert Bentley
    Passat R36 Saloon
  7. #57
    Oct 2009
    bit of math...
    If it where Metric, in imperial I ran a 11.75 < Yeah, I wish.
    If it where Imperial, in metric I ran a 15.81 < This makes it slower than my W8.
    Neither of these are feasible.
    I'm educated guessing 13.66 in Imperial is the correct one.
    Robert Bentley
    Passat R36 Saloon
  8. #58
    Oct 2009
    The times are pretty feasible really if you think about it:
    The Wagon/Estate is heavier...
    The Wagon/Estate suffers aerodynamically...
    My engine had done ~ 3x the distance so was looser...
    It was only 15deg-c here when I did my run...
    I only carried 1/3 of a tank of fuel...
    I made sure the climate control was off (compressor saps engine power)...
    My engine was given the 'go for a blast' run in treatment...
    ... and, All cars are different. I've seen stock R32's roller between 240-265BHP.
    Robert Bentley
    Passat R36 Saloon
  9. #59
    Feb 2009
    Rob
    LOL...
    It's a reasonable time. hypo's wagon ran 14.25 - the wagon is slower as Rob has said, and it had only done 1500km.
    Mid to late 13s should be achievable in a run-in sedan.
  10. #60
    Canberra
    Lots of things can effect ET (eg traction, driver skill, wind, weather conditions), which is why if you want to compare different cars (or power mods to the same car) the terminal speed is a much better measurement to use. For a given power to weight ratio of similar cars it is a surprisingly consistent measurment. If one car has even 5% more power than another it will show up in the speed at the end.
    The other trick is to watch out for 1/4 miles figures being directly compared with 400M figures.
