Results 1 to 6 of 6
Thread: HELP! Passat 125TDI owner around the Rowville area
    May 2010
    vic
    I'm having difficulty identifying couple of faults on my car at the moment
    due to lack of same model cars to compare.
    Anyone got 2007~2009 Passat 125TDI Pump Duse BMR engine and want to test out the following?
    1. DSG jerkiness
    2. high pitch noise at pre ignition
    3. resonance at 1200rpm to 1400rpm
    4. mirror dip function
    We can even gather couple of people to sample from bigger pool
    No?
    May 2010
    vic
    No one cares about me.
    /wrist
    Queensland, Australia
    I've got family in Rowville with a Triumph and a Toyota... don't think they can help!
    Tony.
    2008 Passat 125TDI DSG, Leather.
    2007 MkV Golf GTI - APR, 188kW, Leather, Manual.
    May 2010
    vic
    Quote Originally Posted by antone_86 View Post
    Haha that's alright mate.
    Thanks anyway.
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by mebius9 View Post
    1. DSG jerkiness
    No?
    1. There is a software re-flash of the DSG control unit, although, it depends where the jerkiness occurs. If it's a harsh downshift from 2nd to 1st as you're pulling up to a stop, it'll usually require a fresh Mechatronics unit.
    2. Pre-ignition, as in cranking over? It's usually fixed by removing the starter motor, and lubing the ring gear and pinion with moly grease.
    3. Not sure. Is it a moo-ing noise? Some cars had revised intake pipes.
    4. Only on cars with leather heated seats, apparently.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2010
    vic
    Quote Originally Posted by Umai Naa!! View Post
    1. done the software re-flash 3times no change and getting worse day by day
    2. even before the cranking it's a super high pitch sound like broken capacitor
    3. 50hz like this YouTube - 50HZ but much louder
    4. I gave up on this...
