Results 1 to 3 of 3
Thread: Help: Installing LED strip in boot
    Dec 2012
    I've got a 12V 0.3A 3.6w LED strip which I want to hard wire in my boot.
    If I tap into the existing boot light (standard halogen) would it work, if so, will I need to keep the halogen light in to make sure no errors pop up?
    MY11 B7 Passat 125TDi Highline
    Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
    Aug 2007
    I think that you will be right. I tapped 2 x 48led grids into both sides of the golf gti with no issue. I don't think the computer cares if your boot light is out. I also replaced by oem boot lamp with a led festoon bulb and that worked great.
    Dec 2012
    All good..
    Connected LED straight to the factory boot light wires. Installed a switch too, the LED strip I got is brighter than the OEM DRL hence the need to install a bypass switch.
    No errors, no light in the original housing.
