Originally Posted by
weiz
In addition, I question the TDI + Blue motion package. We all say diesel engine is good at long trips. During these long ones Blue motion tech would be useless. I believe start/stop system is designed and used in traffic/city. So it sounds like TDI and Blue motion should not stay on one car.
The variable rotor voltage alternator system would still reduce loading by the electricals when the car is being driven by the engine on highways and and the aerodynamic package will only have noticable effect on fuel consumption on a highway. Plus the lower rolling resistance tyres and taller gearing will aid fuel consumption all the time and the gear shift indicator will help teach you the optimal point to shift even out of the city.
But that's the full Bluemotion package and we don't get that variant here.
Resident grumpy old fart
