Hi Neromonk,
In my case the dealer put in a "Goodwill" claim to VW. I didn't request this so not sure whether it was due to the relatively low kms of the car. VW's response was apparently a 50/50 cost share for the repair. The total cost for the initial inspection & diagnosis before Christmas and the subsequent supply and installation of the new module in early January was $757.10.
If you google the part number it is available on a few OS web sites but not sure on the change out process or required resets via VCDS.
As mentioned in an earlier post I had already changed the switch myself prior to the above repair at a cost of around $95. I purchased the switch from a different dealer and the change out process was very simple with the help of Google although the release clip to unplug the switch from the wiring loom was a pain to operate.
After replacing the switch I tried the disconnect battery trick to to see if that would reset the error without success.
