If your in for service no doubt they'll sort it out.
I'm Bris south side if you want me to scan & or clear faults for you. If so just send a PM.
Passat battery was too flat (just) to turn it over after holiday so I carefully read the manual and followed instructions to the letter.
All went well car started and runs ok.
However the following is strange.
Firstly the electronic park brake switch wont turn off by pushing down on it . If I pull it up when its on it turns off ????????
The electronic Park brake light is flashing orange in the left binnacle.
The Airbag fault light is lit permanently in the right binnacle.
Any advice would be appreciated.
It goes in for a service on Wednesday so maybe Just maybe I might fluke a dealer that can fix it easily and without breaking the bank.
I probably shouldn't have left the park brake on for the 9 weeks I was away.
Let them know you had a flat battery, and go from there.
As said, chances are it will have logged a few low voltage codes.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
My flat battery logged about 30 codes as all the computers were suffering from low voltage issues. Not a big deal and should be cleared when you get your service.
this message thrown at you from the window of my flying Golf!
MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
All fixed thanks Dealer reset codes and all is good Pleased with price for 45k service as well $307 with oil I supplied
glad to hear all sorted for you. any chance you know how did the dealer reset? is that something VCDS able to do?
Unsure, I have been able to reset all fault codes that i have come across with gti's and passats.
