Results 1 to 5 of 5
Thread: H7 Bulbs HID replacements
    Dec 2007
    ivanhoe vic
    Are these legal, suspect not, guys in the US seem to like them. Want to upgrade headlights after driving wife's V40 with xenons, have recently replaced both H7 bulbs but still not impressed.
    These ones are designed for reflector housings
    VWVortex.com - H7RC DeAutoKey install and review
    B6 Passat Wagon No KESSY
    Jun 2009
    So it's a xenon bulb in a reflector housing?
    Better of just getting some Osram Rally's.
    Pacific Paradise QLD
    No they wont be legal as no self levelling and no washers About $4000 to do full legal retrofit according to another thread.
    Unkonwn_User Guest
    Since everyone jumps on the legality band wagon I'll actually attempt to offer some valuable input.
    I did quite a bit of research and decided that xenon bulbs in a H7 housing are not worth it.
    1) the beam pattern will never be right. Halogen designed housings send more light upwards and it will never look right.
    2) aftermarket ballasts can burn other components due to spikes in power usage. This is reported on Audi's and VW's with and without 'canbus safe' ballasts. This is a headache I did not want... Most common is a blown wiper motor.
    On a side note Auto levelling is bull ****. I get blinded by many many many factory xenon cars that go over small bumps on the road. No auto levelling can adapt that fast. I.e unless you go from 0-100 at full throttle and the front of your car is slightly raised they offer little assistance.
    All in all doing a quick and cheap attempt was not satisfactory for me. I would recommend buying some good quality Osram or Phillips units for optimal performance (some are very white)
    Jan 2011
    Brisbane - QLD
    Auto levelling is not designed to work on road bumps. It is designed to correct beam height when the rear of the car is loaded with stuffs or 3 sumo wrestlers.
    MINI Cooper S Clubman - FWD
