Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: Fuse for a fuse tap
    Pacific Paradise QLD
    Quote Originally Posted by Mylotian View Post
    I appreciate the help but neither the book or your photo matches what is on my driver side of the dash fuse box so is your photo the left side
    (attached is a photo of the right side)
    CheersAttachment 6986
    That is just a bigger photo of what mine is and some of the fuses are different. You can see the same corner by the top one in my pic with the wire coming out of it
    Just get a meter and test the one beside the 10amp in 2nd top row That's where mine is.
    The other one is two rows down beside the 10 amp one again. The full size fuse row
    Both of them are stuck in what were blanks previously
    The blanks in most of them have the metal grips in the top half of them and that's all you need to get power for a fuse with the wire on like I used YOU DONT NEED TO PULL ANY FUSES
    Try the ones by the 30amp green ones Any blank will do just get someone to turn key on Put meter in the blanks and turn key off You will soon find one Most of them have the side that comes from the car and not the other side but the fuses I used give power perfectly Look at the pics in the link I gave you all the fuses are shown and designated below the picture of the box
    Cant be more specific than that
