Results 1 to 10 of 11
Thread: Fuse for a fuse tap
    Dec 2013
    Western Australia
    Fuse for a fuse tap
    Installed some DRL on Passat 2009 Wagon need to know which fuse in engine bay live when ignition turned on so connect fuse tap to run power to the lights
    Manual useless as fuses don't correlate to whats in book
    Thanks
    Pacific Paradise QLD
    Quote Originally Posted by Mylotian View Post
    Thanks
    The fuse box is in the end of the dash and you will find a blank in there that you can put a fuse into that you can buy from Jaycar with a wire already hanging off it
    Read the stickies in the Passat forum and you would get a lot of answers
    http://api.viglink.com/api/click?for...13879368848426
    Here is a pic of my fuse box with the two fuses used for my Power Magic for the dashcams.
    One is permanent power and one is acc power only which is what you want Attachment 6962
    Cant remember which is which but a quick check with a multimeter will tell you
    Part numbers for Jaycar fuses are SF5110 for standard size SF5120 for mini
    Read that link for info on fuse placements.
    Dec 2013
    Western Australia
    Hi thanks for the reply actually looking for one in engine bay so don't have to wire through firewall
    Merry Xmas
    Merry Xmas
    Look in that link and the bottom pic of B6 fuse locations is an engine bay box that maybe your car has
    Number 8 is a likely location as designated as not used.
    Pays to look through the stickies as it saves typing it all again
    The search function works with the right questions as well
    Dec 2013
    Western Australia
    Thanks again
    Dec 2013
    Western Australia
    Took out the wiper motor control SB22 in engine fuse box to see if could run from there now can't seem to get wipers to work and fuse looked oK so panicked thinking what have I done then went to go to local auto shop to get another fuse just in case reseated the fuse I took out again for a third time closed bonnet etc tested the wipers and they worked. OK
    Tried the Sb8 fuse with a fuse tap but appears getting power even when engine off so still not sure which fuse to use only when engine on in the engine bay
    Took out the wiper motor control SB22 in engine fuse box to see if could run from there now can't seem to get wipers to work and fuse looks OK????
    There is a lot more to VW electrics than is obvious if you don't understand how they work or what you are doing.
    Get a multimeter and someone in the drivers seat and test the blank ones to see which has Aux power only and use that one Probably all under the bonnet will be live and the control will be in end of the dash
    Dec 2013
    Western Australia
    Yeah might be a case of having to route through firewall, have a multimeter and tested appears all the ones that I tested in engine bay even the empty ones are live. Did find one in the right hand dash fuse box that runs air con only live when engine on
    I found out if you leave indicator on when turning the motor off one of the front park lights stays on and you get an alarm chime. Also appears wipers and/or washer won't work when the bonnet is up, neither of these things have mattered on previous cars I've owned.
    JEEZ I don't know Try the two in the pic I posted. Both of them are blank in most cars ONE them is an ACC feed USE THAT ONE
    Don't go pulling fuses when you don't have to.
    You cant go loading up VW circuits wily nilly or car can go into limp mode if computer detects outside of normal parameters
    You ask us for help and when I tell you a way that works you try the opposite. Sometimes I wonder why I bother.
    Dec 2013
    Western Australia
    I appreciate the help but neither the book or your photo matches what is on my driver side of the dash fuse box so is your photo the left side
    (attached is a photo of the right side)
    CheersFuse for a fuse tap-fuse-001-jpg
