Results 1 to 8 of 8
Thread: Newbie Question :) - Passat 1998
    Nov 2009
    Rowville, VIC
    I own a Passat 1998 (manual), and I have a few questions I hope someone can shed a light on. I have just taken this car for service.
    1. I noticed that starting the car isn't quite as smooth as usual. When I put the key into the ignition, usually I can start it with one go without having to pump the accelerator. I have had the battery replaced (RACV) yesterday, and it seems to be OK, except that it sounds like the engine almost dies when I start it (the engine rev goes up and down quite frantically)
    2. What's the ideal idle rev speed? Mine is steady at around 9000rpms, I think it was slightly higher before.
    3. During low speed - low rev condition, for example when I am parking the car or getting the car out of the garage, I find myself having to pump the accelerator more than I usually have to. Otherwise, the revs drop and the engine dies. What happens?
    Throttle body adapation is my guess. What engine do you have, is it turbo?
    Dec 2008
    Sydney/Canberra
    You shouldn't need to pump the accelerator at all on an electronically fuel-injected car.
    As Gavin suggested, the throttle body make require an adaptation, or "re-learn".
    Also, the throttle body may be dirty and carbon'd up.
    Nov 2009
    Rowville, VIC
    Quote Originally Posted by Umai Naa!! View Post
    Thanks. How do I get the throttle body to re-learn?
    And if it is dirty and carboned up, how do I clean it?
    Dec 2008
    Sydney/Canberra
    A VW dealer will be able to carry out a re-learn for you. After it's been cleaned, of course.
    Nov 2009
    Rowville, VIC
    Thanks, so there's no way I could've done it myself huh.
    I'll bring it to them later then. Again, thanks
    Nov 2009
    Rowville, VIC
    No, not a turbo
