fuel sender is faulty. you will need to get someone to replace this or do it yourself however you need to open up the thank. same thing happened to my gti. happens regularly right after I fill up gas and now during a drive it will just go to empty and km left goes to -----.
check vcds and you will most likely see something similar tot he following.
00771 - Fuel Level Sensor (G)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 229
Reset counter: 117
Mileage: 99639 km
Time Indication: 0
Date: 2000.00.00
Time: 07:31:01
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 103601 km
Time Indication: 0
Date: 2000.00.00
Time: 18:14:41
