Front strut remove & install
I'm in the middle of upgrading the front struts (and springs) on my B6 Passat. Despite using a spreader tool in the split of the hub/wheel bearing housing, I've found it quite difficult to remove the strut due a tight fit. When installing the new Koni struts, it's proving to be even more challenging to insert the strut to the full depth inside the hub. What I thought would be a simple job is taking forever!
Has anyone stuck a similar problem? Any tips?
There are two main methods to install: (1) attach the top of the strut to the turret, then engage the bottom of the strut with the hub and lift up the hub, with a trolley jack if necessary, so that the strut fully enters the hub or (2) insert the bottom of the strut into the hub first and bolt in, then lift the complete unit up into the turret and attach the top of the strut. Any tips on which method works best?
Thanks.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
