Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: Front Light Assist and Dynamic Light Assist
  1. #21
    Mar 2012
    Mount Annan
    Hi booba.
    I have factory xenons with assistance options. I'm a bit confused with which state controller a5 needs to be programmed for byte 2 to enable dynamic light assist. Could you please explain the coding for light assist.
    Thanks
    Garry
    2012 Tiguan| 132 DGS |Deep Black Pearl|Comfort Pack|New York Alloys|Tow Kit.
    2012 Passat| 125 DSG|Deep Black Pearl|Driver Assistance and Visibility Package|Reverse Camera|19" VW Sagitta Wheels.
  2. #22
    Pacific Paradise QLD
    Quote Originally Posted by kleung View Post
    Isn't the other light just the indicator?
    You can see the movement range when they do their self test when you first start the car. The actual behaviour in normal operation will be different (they won't both go outwards at the same time, for example), but at least you can see how far out they can go.
    If I remember correctly maximum is 15 degrees of turn and if you are doing under 15kph your corner lights should come on as well.
    I was turning in a car park tonight and my friend was walking towards the front of the car. He said you have one side light out.
    Was turning left and the left cornering light was on. Car has LED DRLS so wouldn't be a side light. LOL
    If you turn the car on with heads on Auto in a dark garage they do the leveling etc trick. Mine did it tonight to show the friend all the bits.
  3. #23
    Aug 2007
    Go into controller a5 coding.
    Go ti Byte two ensure there is a tick box on bit 0 and there isn't a tick box on bit 1. The resultant value of this byte should be 01. The starting byte should have 00 so bit 1 shouldn't be ticked anyway.
    Quote Originally Posted by ganue View Post
    Hi booba.
    Thanks
    Garry
  4. #24
    Mar 2012
    Mount Annan
    Thanks. I still can't get it to work though.
  5. #25
    Mar 2014
    Toowoomba
    Hi Booba,
    It is good to see that you have worked out the high beam assist coding for the Passat. I have a CC with the driver assistance package and would also like to enable High beam assist. I purchased a Vagcom from Rosstech in the hope the codes may have been the same or similar. On my first attempt I succeeded in bringing up an error code, "cornering light failure" Took an hour of research before I found the solution.
    Do you use the long code helper in Vagcom?
    I am an absolute newbie when it comes to this any help would be much appreciated.
    Cheers Gray
  6. #26
    Aug 2007
    Hi Guys,
    I will take some screenshots this weekend to make it clearer.
    Jeremy
  7. #27
    Mar 2014
    Toowoomba
    Quote Originally Posted by booba View Post
    Hi Guys,
    Jeremy
    Cheers Jeremy, appreciate your help.
  8. #28
    Sydney,NSW
    Hi Guys
    I too is interested in getting the high beam assist. I have in my passat the factory HID which came with the Visibility package and as well as the camera above the rearview mirror for lane assist perhaps. My car also has active cruise control if that helps.
    Will the following options enable my car to get this high beam assist? If so I am happy to pay for your time in sydney to code it for me please?
    Thanks
  9. #29
    Jan 2014
    Thanks, Booba for all your efforts - much appreciated.
    I am in the same position as cru22z above with the same package on our new car.
    Thanks.
  10. #30
    Sydney,NSW
    Quote Originally Posted by 2VW's View Post
    Thanks.
    Any updates anyone??
