Originally Posted by
kleung
Isn't the other light just the indicator?
You can see the movement range when they do their self test when you first start the car. The actual behaviour in normal operation will be different (they won't both go outwards at the same time, for example), but at least you can see how far out they can go.
If I remember correctly maximum is 15 degrees of turn and if you are doing under 15kph your corner lights should come on as well.
I was turning in a car park tonight and my friend was walking towards the front of the car. He said you have one side light out.
Was turning left and the left cornering light was on. Car has LED DRLS so wouldn't be a side light. LOL
If you turn the car on with heads on Auto in a dark garage they do the leveling etc trick. Mine did it tonight to show the friend all the bits.
