![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
J-P
Hi all,
I have a few niggling questions I was hoping Passat MY10.5 Highline owners could answer for me.
1. Recently my Front Assist setting randomly is off when I start up the car. In the past it always remembered it was at the on setting and stayed that way. I can't seem to make rhyme or reason what makes it switch off but it's about 10% of the time. Does anyone else experience this? I took it to the dealer and they have no idea why it's switching off and it's hard to demonstrate. This bothers me the most because I like having a warning when the car in front of me slows down suddenly. It has saved me from a collision a couple of times.
2. Similar to 1 my Lane Assist setting randomly is off on ignition and I seem to remember it staying always on. This happens about 90% of the time and again I can't work out what makes it go off or stay on, sometimes if I take the key out and put it back in a minute later it is off, other times it stays on hours later.
3. I have Bi-xenon lights and I don't have Daylight Running Lights even if I follow the manual guide on how to turn them on. I seem to remember these were on when I bought the car but I could have been wrong. When I bought the car I though it was listed as having DRLs. The dealer tells me that DRLs are not available if you have bi-xenon lights. Is this true? If so can they be switched back on with coding?
Recently the dealer replaced a park brake switch claiming this would fix 1 and 2 but it hasn't. I can't seem to find any info about this in the manual or online so I'm hoping the community here can help me. Also not sure if the Front assist and Lane assist settings are meant to be remembered globally or per key.
Thanks for your assistance.
Mine is a MY11 but has Xenons and has LED DRL THEY COME WITH XENONS ONLY as part of the driver assist package. Mine go all the time and cant be turned off. Looking at pictures of your model on the net the Xenons DONT appear to have the LED DRLS but do have a strip in the bumper which may have them
The lane assist only comes in at a certain speed 65kph?? if I remember correctly Front assist (adaptive cruise) can be setup in the MFD as to distance etc A good read of the manual will tell you Mine is away in the car ATM The two indicators are always in my dash displays They are orange when off and green when working. Both can be adjusted in the MFD
City braking is a different part of the Driver Assist package and only works at lower speeds.
