Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Front Assist, Lane Assist, and DRL questions
    Pacific Paradise QLD
    The Bluemotion ones have a different battery as I understand it as they have regenerative braking etc The guy said it had a chip in it and was a pretty fancy design and it is an AGM. CAr also has stop start so will require a bit more than an ordinary one
    Its a VARTA AGM 7PO 915 105 68AH 38A DIN
    Feb 2010
    NSW
    Fair enough but you'd hope they would last significantly longer than a standard battery too or it could offset the fuel savings for having Bluemotion. Luckily if yours if for your 2011 Passat then it should be replaced under warranty.
    2010 Passat 125TDI Highline Wagon / ACC / Bi-xenon / Lane Assist
