If a battery wont fix it, it's pretty much dead. Does the little red LED on the fob work?
You'll need to replace the fob. You can keep your emergency key, though.
This one has me stumped. My usual fob key stopped unlocking / locking car and open boot function doesn't work either. Also no flashing of indicators.
Once inside car fob key starts engine fine so obviously(disabling) the engine immobiliser function works. Replacement of fob key battery as per sticky (great sticky by the way) made no difference.
Is this a key coding issue or just a simple key failure? The second key that has only been used about 10 times til now works fine so I don't think the issue is with the car itself.
As the mechanical key setup really is just for emergency use, I really want to get a second key working without having to get a replacement at exhorbitant price.
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
'07 Transporter 1.9 TDI
'01 Beetle 2.0
i wouldnt be surprised if its just lost its setting to the car. if the little red light still lights up on the fob that would suggest its still ok. I believe on this forum somewhere it states a method to recode it to the car manually. Otherwise a trip to a dealer or workshop.
It will most likely be covered by warranty, unless you took it for a swim?
Bad news is that replacement is $355.21 + GST + 1 Hour labour for coding = $533.75
Good news is that extended warranty (Allianz) is covering the cost. It hadn't been swimming but they didn't even ask the question, just accepted that the transmitter had failed and gave the dealer the authorization over the phone.
Spot on Busuki!!!
