Results 1 to 10 of 48
Thread: Fiscon bluetooth question
    Apr 2009
    Quote Originally Posted by Swallowtail View Post
    OK...
    Instead of a quick push and let go to dial, push and hold the speed dial button. after a few seconds release, and it will go to an edit screen on which you can delete or edit it.
    Hi Swallowtail,
    Who installed yours in Brisbane and were you happy with it? My work has agreed to buy and install the unit.
    V6Passat
    V6Passat
    Here now!
    Feb 2009
    V6Passat
    I bought it from Kufatec in Germany directly and then I installed it myself... Took about an hour. Pretty sure Northfield at Moorooka (who did my stereo upgrade yesterday) would be able to do it though.
    You have to remove the two little drawers above the stereo, remove the faceplate around the stereo, undo the torx screws that hold the stereo in place and pull it out. Feed the BT unit down the back, wire it up (really easy) and run the mike to where you want it. I have mine on top of the steering column, works really well there.
    Finally a VAGCOM code change and it's all done.
    May 2009
    Q
    V6Passat
    Would Northfield supply the Fiscon too?
    I'm wondering whether to order the unit from Kufatec or oemplus?
    Couldn't install it myself even though I have done such things on my Accord Euro - just not that way inclined anymore unfortunately. Leave it to someone who knows what they're doing.
    Feb 2009
    Quote Originally Posted by Luminary View Post
    Not sure - ask them and see... Andrew was the guy there I dealt with. Check out how much to get one in from Kufatec and compare. THey'll install it even if you get it.
    Jun 2009
    Around
    Anyone got a quick link to the site in Europe to buy these from and possibly a part number?
    Might as well order one now ready for the arrival of the vehicle so it ready to put straight in
    Apr 2009
    I just had my UHV low kit removed as no-one could get it to work properly, Northfield supplied and installed a Fiscon kit yesterday, Perfect.........
    Feb 2009
    Excellent! How much supplied and fitted?
    Same deal for me, $995. Northfield highly recommended.
    Black R36 Wagon
    Apr 2009
    Same $995 great service......
    Jul 2009
    Templestowe, Victoria
    Does anybody know any installers in Melbourne for the Fiscon Pro?
