Results 1 to 10 of 13
Thread: first service 5000km late?
    Sunshine coast
    I'm negotiating to purchase a used 2011 model VW Passat TDI highline from someone privately. It's done about 24000km, and first service was done (at VW) at around 20000km. Should I be concerned about the service being done 5000km late? I would run it through an NRMA Vehicle inspection in any case.
    132TSI Tiguan Allspace
    Dec 2008
    Sydney/Canberra
    I wouldn't worry about it too much. Get the book back on track by getting it serviced at 30,000klms, and then every 15K from there on in.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2008
    Perth, WA
    First service is oil and little else. Far from ideal (I change oil in tdi's every 7500km) but not the end of the world.
    Adelaide hills, SA
    I would give it a pass. Obviously, the driver/owner didn't care about the car at all, not a good sign.
    Sunshine coast
    He said he simply ran out of time and didn't get it to the dealer until it had ran 20000km. A Diesel is oiled by the fuel as well, isn't it?
    Dec 2008
    Sydney/Canberra
    Parts of the fuel system, such as the high pressure pump are.
    '01 Beetle 2.0
    Sunshine coast
    I might pass on this one I guess. It's a bit far away from where I am as well: VOLKSWAGEN PASSAT 125 TDI HIGHLINE 3C MY11 4D WAGON - Merimbula - NSW - $ 36,100
    Dec 2008
    Perth, WA
    I would never personally let a diesel run that far without an oil change. Oil that old must be in a frightful state.
    Jan 2009
    Quote Originally Posted by Umai Naa!! View Post
    I agree, it's nothing to be worried about.
    Quote Originally Posted by iampivot View Post
    Good idea, as I'm sure you can find better examples.
    Quote Originally Posted by kryten2001 View Post
    That is not a given.
    Depending on how it's driven, the operating conditions faced, quality of the fuel and the type of lubricant used, modern engines specifically designed for extended drain intervals, are in fact capable of extended drain intervals - like the FSI/TSI/TDI engines from VAG.
    I'm not saying the drain interval for every TDI engine designed for LongLife servicing & using 507.00 oils should be no less than 30 000 km, but the way VW have engineered the entire system certainly makes that possible.
    A single oil change at 20 000 km, though not ideal - given the specified drain interval for this country is 15 000 km - is not a disaster.
    Dec 2008
    Perth, WA
    Yeah mate I agree it wouldnt be a disaster with the quality of modern vag engines but I certainly wouldn't do it...
    Every 7500 for me.
    The stuff that came out when I did my 7500 oil change made me a convert to the virtues of frequent oil changes in diesels.
