Results 1 to 9 of 9
Thread: Fan kept running after turning engine off
    Sydney,NSW
    What does this mean??i experienced it after a long trip to Melb. I didn't know how long it was gonna keep running so what I did was switch the car on then off and then the fan didn't run again
    May 2007
    Quote Originally Posted by cru22z View Post
    So much to learn on these cars...
    Generally speaking, the fans run up to about 5mins if it is under going a regen.
    Other than that, they should not run for longer than a couple of seconds after switching the car off.
    I would not turn the car on, then off again though...Just let it do its thing!
    Mar 2012
    Tamworth NSW
    Mine did the same thing last week mate and I did the same as you. Now I know the process is to let it do its thing.
    Dec 2008
    Sydney/Canberra
    The fans will run on for an extended period of time under certain conditions, such as drive time, ambient temperature, and coolant temperature. The idea is to stop the car boiling itself once there's no coolant circulation when the engine is switched off.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2009
    Australian Delivered cars are fitted with this feature, if the Oil/Water temps are above a certain level the car will keep the cooling fans running after you park the car to help cool down the engine. They run for about 5 minutes or so, it's normal, don't worry about it. It won't send your battery flat or anything like that.
    Dec 2008
    Sydney/Canberra
    Correct. If the battery voltage is affected, the fans will be shut off.
    '01 Beetle 2.0
    Sydney,NSW
    i hope i didnt damage anything when i turned car on and off just to shut the fan..at-least now i know though. Thanks fellas!
    Mine surprised me too the first time it did this at around the 1000km mark. In my case I am sure it was due to a DPF regen, as there was an obvious smell of burning exhaust paint at the same time due to the high temperature of the DPF. It has happened a few times since (at similar intervals) and the burning paint smell has now diminished. Just let it happen!
    MY12 B7 Tdi Highline Wagon | Reflex Silver | Sport Package | Dynaudio | Towbar
    Mar 2012
    Brisbane QLD
    Up here in Brisbane, especially in summer, the fan will kick on for 5 minutes or so on a regular basis.
    It's a surprise the first time but you get used to it.
    Clever engineering - looking after your engine.
