Results 1 to 6 of 6
Thread: Failed Haldex pump repaired - less than $200
    May 2015
    Wynnum, QLD
    A big thanks to Michael Weber at Performance & Prestige in Brisbane who fixed a failed Haldex pump on my R36 wagon. You have no idea how much work the Haldex does until it stops working! When mine went suddenly 2WD I figured on a huge bill for a new Haldex unit. But P&P simply stripped down the pump, cleaned, resealed, re-lubed and I was back on the road in full working order for less than $200. Outstanding! Apparently they've 'done' a few of these, so if yours plays up I highly recommend giving them a call...
    Jul 2013
    Hills District
    Whats the symptom of a failed Haldex pump?
    May 2015
    Wynnum, QLD
    Give it a bootful at the lights, and the front wheels spin like crazy, Traction control lights fires up etc. Doesn't happen with a working Haldex. Thence onwards to VAGS diagnostics indicates failed pump. But it becomes really obvious as soon as it happens as the whole dynamics of the car change (for the worse). I don't think it could ever go undetected!
    Jul 2013
    Hills District
    OK, thanks, will pay attention to this!
    Nov 2010
    Thanks for the tip mate. Appreciate it.
    Jul 2014
    FYI this is what I also went through but blamed my tyres before diagnosing the fault. No pump means you're not pressurising to drive the clutch which means your rear wheels are permanently disengaged, which obviously means no AWD so less grip and thus the issues the OP describes. If you baby the car it will actually be hard to notice mostly, if you're an enthusiastic driver you will notice something is off pretty quickly.
    My pump is probably not repairable as the death of mine was an electrical fault, you can also just replace the pump with new, it's a $700 part or closer to $600 if you know someone in the parts department. For my car the part number was 0AY598549A but best check with VW as yours may be different.
