Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: External Lighting
    Apr 2008
    The bulbs (high, low and fogs) are a bit tricky to install, as they have to be fit snugly into place so that they sit perfectly in the 'focal point' of they fisheye lenses. Otherwise the beam will be useless, as I have found out from experience.
    Herein lies the problem, because the bulb mount has a non-uniform outer rim which must be married up perfectly in order to clip in. The opening in the back of the light assembly is just big enough to fit my hand thru, holding the bulb. You cannot see what you are doing, so you have to feel for it, which is awkward, but eventually doable.
    I managed to fit the high and lows myself, but for the fogs i just got a mechanic to do it, as it was in there with them at the time i bought the bulbs.
    I would recommend getting VW to fit them during a service. I'm sure they will do it if you supply the bulbs. I still don't know for sure if my bulbs are sitting correctly, so will be getting VW to check them next time its in there anyway.
    RIP! 2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
    Aug 2008
    Mudgee NSW
    Quote Originally Posted by tryingavw View Post
    no the bi-xenons are basically fixed but do a little jiggle on startup -levelling? The "turning" bit is actaully a 3rd globe ( regular 55w halogen - yellow tinge) and lens system offset at around 45 degrees. when you turn the steering or put on the blinker the relevant side lights up!
    Now I'm more confused!
    Here is a quote frm the Passat brochure. "The Bi-xenon headlights with dynamic cornering light system swivel to illuminate the cornering path."
    This suggests that it has swivelling (dynamic) and an extra fixed (desrcibed elsewhere in the brochure as static) cornering light.
    The only car I have driven with xenon lights is my brother's GTI which has a single fixed xenon. So, is the swiveling part of the lights a noticeable action whilst driving?
    It is a noticeable action. It is very obvious and the brochure is right, the xenon itself swivels and the cornering light turns on and off when you make a turn.
    Jun 2008
    Quote Originally Posted by olcoop View Post
    thats quite possible but i haven't noticed, but the extra globe lighting up sure gets my attention!
    i will check that out at night and get back to you.
    had a passat tdi. now mb c class.
    Aug 2008
    Mudgee NSW
    Thanks for clearing that one up guys.
    I didn't know about the extra turning light that switches on when turnining into driveways etc.
    Jun 2008
    i checked and as well as the side light, the main and hi beam lights also turn with the steering but not very much.
    Jun 2008
    Quote Originally Posted by First VW View Post
    and heres a picture with philips diamond vision (H7) globes fitted in place of standard halogens. much brighter and colour match the xenons as well .
    found them on ebay for $ 61 posted from hong kong, about $130 locally .
    heres a link:
    http://cgi.ebay.com.au/ws/eBayISAPI....m=280301694547
    Feb 2008
    Ringwood North, VIC
    Smile
    so no lighting faults with these fitted??
    thanks
    Matthew
    2010 MY10.5 R36 Wagon, Biscay Blue, RNS510, Dynaudio, Sunroof, towbar, Dynamic Chassis Control, No lazy back door
    2008 Audi Q7 4.2TDI, Radar Cruise, Lane Assist, Blind Spot Assist, Heated Seats Front & Rear, Alcantara Hood Lining, Wooden Gear knob, Nappa Leather, Plus all the usual V8TDI gear, like 760nm of Torque!
    Jun 2008
    Quote Originally Posted by Caddyman View Post
    thanks
    Matthew
    no they work just fine. very bright
