Quote Originally Posted by Autopia View Post
If you're concerned about fluctuating tyre pressures as the seasons change then one solution would be to use nitrogen. Many people use it as it is not as suseptable to temperature change so it maintains the tyre pressure at a far more constant level. If you've ever seen a car on the road with red valve caps it because they're running nitrogen. I use to run it in my Clio Sport and only ever got an increase of 1 PSI on a stinking hot day after some hard driving.
Where can I find a nitrogen pump in Sydney? How much for a fill / top-up?
Used to use nitrogen when overseas - one time cost when replacing the tyre and free top-ups for life... tyres ran cooler with more stable and consistent pressure...
