Hey Guys,
Having trouble with intermittent Hand brake faults. About 1 in 10 times I get in the car and turn on the ignition and before I touch anyting I get a " Hand Brake Failure , See owners manual" on the MFD.
If I press the handbrade button the handbrake will not release. The only way I can get the handbrake off is to remove the key completely and then turn back on. Most times everything is working fine again. I have also had it where, after pulling up and to park I get the same message and I can't get the hand brake ON. Solution is the same by removing the key and re starting, I can get it to engage.
I just had the 30,000km service and mentioned the problem but they said they could not fault it?? They said there was also no errors reported in the computer. I have booked it in again for them to look at in a couple of weeks but if anyone has seen this before, I may be able to give the dealer some direction.
If I get permanently stuck somewhere I will be might pissed!
Thanks
Rotelman
Passat MY09 125TDi DSG Wagon - Arctic Blue
Tint,Tow,E-Tailgate, Roofbars & Cow,Fog, 12GB SDHC
VW Bluetooth
I've also had my park brake button replaced now hopfully I'll not have a problem again.
I have had two park brake button replacements... fixed under warranty but annoying none the less.
Mk 7.5 Golf R
We've had two also. They're $94 each. Annoying.
I sent my mother to a skid pan day for her bday (she likes this stuff), she took the passat and it was a total waste of time![]()
mmmm cool mum!
BTW, How do you do a handbrake turn with a push button job?
V6Passat
Here now!
Nope, sorry, bulletin was Golf, Jetta & Tiguan only, no mention of Passat. A trip to the Service Deparment I think...
Dermot,
Could you advise when the bulletin was sent out fo the Tiguan?
Mine is due to arrive next week so i want to make sure the dealer checks the handbrake issue has been rectified.
Dont forget if you fit a new switch it wont clear the fault, nor will clearing it with a scanner. You will need to do a terminal 30 reset to do it properly.
Jmac
Alba European
