Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Dynaudio amp won't fit!
    Apr 2013
    I'll get the actual part number tomorrow, but for what its worth, its a Blaupunkt unit and it says ""8 Channel Amplifier" on the top... so its definitely the device I'm looking for!
    Will advise!
    Rgd's
    AT
    Feb 2014
    Quote Originally Posted by Timlin View Post
    Yeah, that's not a good sign.. hopefully we can find out more about the connector used from the part number.
    A pinout diagram/numbering would be most helpful. Also be good to determine the type of plug used (if standard).
    With some luck, we can track down a male 'Lear' plug and female 'Blaupunkt' plug and wire them together using the Lear (which we have) and Blaupunkt (which we need) pinouts. Otherwise, the next option is to splice in a male 'Lear' plug (possibly harvest from a wiring loom). Then, the other (less appealing) option is to splice & solder wires from the loom directly onto the Lear amp (or at least an intermediary plug) =S
    Worst-case scenario, you can always re-sell the amp...
    -- Does anyone else with a non-Dynaudio R36 have a different plug on their amplifier? It will be good to find out which vehicles have what plugs - maybe the Plug-n-Play retrofit only works with the 2008 model??
