Results 1 to 10 of 12
Thread: Dynaudio amp won't fit!
    Apr 2013
    Hi
    I tried to replace my old amp with a new Dynaudio (Lear) amp today as I've read that it was a "plug 'n play"... sadly it hasn't worked like that for me.
    The existing cable loom has a completely different plug system to the new amp. So I'm not too sure what my options are here. It took quite a while to find the new amp too, major bummer!
    Rgd's
    AT
    Attached Thumbnails Attached Thumbnails Dynaudio amp won't fit!-photo-1-jpg   Dynaudio amp won't fit!-photo-2-jpg
    Feb 2014
    Yikes!
    What year is your R36?
    The Dynaudio (Lear) amp looks like the photo on the left? (it looks new)
    Is the factory amp on the right? Does it look like the one pictured below? Also, can you please post the part# if possible so I can try track down the details?
    Not sure how your loom is configured, but if the number of pins are compatible, you may be able to create an adapter plug - just need to track down a wiring diagram.
    If you were in Brisbane, I'd be happy to help out. Otherwise, it'll be a little while before I'm down Sydney again (at least a couple weeks or more).
    Feb 2014
    FYI - I've updated the retrofit guide to warn others that there may be different versions of the pin-outs..
    Apr 2013
    Hi
    My car is a MY2009 (OCT) first registered in Jan 2010.
    The new amp is a: 3CO O35 456C.
    An adapter cable is possible I guess, but where would I get the parts?
    Another bummer is that I also installed my brand spanking new RNS510 (from JKU), and I've lost my reversing camera!
    I'll call Martin at JKU to sort that out I guess, but its very annoying...
    Ha! I make take you up if you're down here in a few weeks!
    Rgd's
    AT
    Feb 2014
    Right, that must be really annoying =S
    Do you have a part number for the old factory amplifier? It's really strange that it uses a different plug configuration - hopefully it may be something else and your amp is in the boot (some other models have them in the boot).
    Once we figure out the part number of the factory amp, I'll do some digging around to see if/where to source plugs/wiring diagrams etc from.
    In the worst-case scenario, there is a good market for the Lear amplifier. Though, personally I'd prefer to resolve the issue and figure out how to make it work.
    I'll PM you if/when I know when I'm down next.
    Apr 2013
    You, Sir are a gentleman indeed!
    I'll remove the OEM amp tomorrow and get the part details back to you ASAP!
    I have a wagon so no boot for me... is there any other hidey holes behind secret panels etc?
    Theres a huge electronic device under my drivers seat but I'm told thats the BlueTooth module. Its huge, and on its way out too as I bought the 9W7 BT unit and I was hoping to have all 3 items installed and talking to each other by now!
    Oh well, we persevere...!
    AT
    Apr 2011
    The plugs need to be turned upside to plug into the dynaudia amp
    Feb 2014
    Quote Originally Posted by R36 DSG View Post
    Unfortunately, the photo on the right (original post) shows a completely different plug... Timlin will provide a part number on the original amp tomorrow - with any luck this is a different component and his amp is in another location.
    BTW - what year is your R36? Is it sedan or wagon? ... there may be more than one wiring system.
    Apr 2011
    Could not view the attached photos, mines an 08 Sedan, I simply reversed the plugs when connecting the new amp.
    Feb 2014
    Right, mine's an 08 Sedan too - same experience.
    Here's the pic - let me know if you have trouble viewing it (or accessing the link below).
    http://www.vwwatercooled.com.au/foru...it-photo-2-jpg
    Quote Originally Posted by Timlin View Post
    Hopefully VW didn't change the plug or wiring after 2008.. maybe we're lucky and they simply moved the amp - I've had a couple people look near the battery in my car for the amp.
