Results 1 to 10 of 19
Thread: Dynaudio
    Oct 2012
    Ok makes sense. Thanks again
    Apr 2011
    You'll find all R36's will have the amp under the passenger seat. The dynaudio amp is all silver while the standard amp has black sides. Cars equipped with the dynaudio upgrade will also have the badging on the speaker grills. Definate way to check is by either getting the part number off the amp or via VCDS
    Aug 2007
    The two little tweeters inside of side mirrors should have dynaudio badge. The RNS will also have a powered by dynaudio on the startup screen.
