Just turn it on and play some music. The difference is night and day- Dynaudio is very, very good :cool:
Printable View
Or if you really want high quality sound, install a decent aftermarket system which will sound even better than the factory fitted Dynaudio.
A decently installed, decent sound system may sound better than Dynaudio if you want to go down that path... but that aint always practical to do so.
I dont think you can achieve a factory (2k) Dynaudio matching sound by putting in 1k of aftermarket gear....
After hating it for the first two months, I missed my Dynaudio that much, that the first thing I did was Bose-ectomy my current car with instructions to try and make it "sound like a Passat Dynaudio..." :facepalm:
To be honest, even the non-Dynaudio Passat gear (atleast in the R36) sounds amazing.
I find though for some reason that media played over the SDCard and Bluetooth sound leaps and bounds better than the AUX.
My last car had two amps, a woofer and proper splits and the Passat audio sounds better.
(Maybe I just chose crap gear, hah)
Parents have the new Holden Caprice with the woofer as well and I still think the Passat sounds better.
This Dynaudio stuff must be amazing if it's that much better than the normal gear.
Meh, because everything was going to be a massive dissapointment after the passat.... i bought an incomparable car, an old Mx5 NC1 roadster as a fun daily driver...:cool: but the worst platform for in car audio ever...
Ripped out the Bose and put in marine grade Polk6 1/2 splits, 6x9s low passed in the cubbies behind the seats and a marine grade Polk 4ch amplifier.... sounds pretty close parked up, but at a hundred with the roof off and windows down... Meh
Can't dynamat canvas!
Anyhow...first world problems!:glasses: and this isn't a miata forum.... the main thing is about a year ago I was whinging about my dynaudio (as the oldies here would know) in the end I miss it terribly... (you may not like it if you are into stuff with a hard core base thump) but most other stuff is great...
It is harsh out of the box, but after you drive it a bit the tweets mellow a little and the big drivers loosen up and step up... for a factory solution I liked it. Also because it was harsh i never turned it up... which prolonged it staying harsh...
