Hi all, can someone please tell me the location of the oil filter on the 6spd DSG in my 2006 passat 2.0l turbo petrol i am going to do the oil change and it appears different to other model DSG boxes. I have seen the filters mounted behind the oil cooler before but mine dosn't have it their.... Thanks
Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
Mk1 twin eng twin turb
scirocco gti 2.1l 16v turb 6spd
Audi A4 B5 1.8t
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
It would certainly seem that way based on the listings at redbook.com.au
They didn't have "TSI" back then. They had FSI and TFSI. (I know that there wasn't an actual change in tech, it was just a change in labelling). Either way, your comment is the opposite to what the specs say. The TDI and FSI cars were DSG, and the Turbo FSI cars were Tiptronic.
If it's got DSG stamped on the gearstick, it's obviously DSG. The only other way I can think of to tell it apart, is that it has a pan on the front side, and one on the passenger's side of the case.
Also, how do you plan on filling it if it is a DSG? Do you have the procedure for it? Pouring 5L of DSG oil down the hole where the filter lives takes an awfully long time, trust me.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
The 2.0T petrol Passat are a 6 speed AUTO gearbox, NOT DSG. Ensure you don't put DSG oil in it as the specification is different. There is a filter in the pan of the auto along with 2 magnets for the attracting the big pieces (if you unlucky). This gearbox is meant to be a lifetime fill, but I'd sugest doing it at no later than 80,000 Kms for preventive maintainace. Before you start, check the two electrical connectors on these transmissions for oil, (the connections should be dry) there's a Feb 2010 TSB on shifting faults caused by oil entering the loom.
Macdoc.
