You will be hard pressed to find a company that will do the DPF delete as it's illegal (max fine $10k)
You could do the DPF delete and then get a tune...
Anyone know a reputable company that does dpf delete and tune around Sydney?
I need the same thing. Understand that mechanics who can do this are reluctant to advertise the fact (although doesn't seem to stop people advertising this service in other states)..... So if I remove the DPF, who can remap the ecu - and not just remove error lights but actually remap properly ala Pendle in the UK?
if you don't want to post here send a PM.
2006 T5 2.5 TDI Manual
I have no problem o do the DPF delete as long as you use your van for the track days only or only off road. Though you have to get the delete pipe and I'll do the software side.
