Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Disable Auto Start/Stop on new Passat
  1. #21
    May 2011
    Melbourne, Victoria
    I had an unnerving incident with the start/stop system at an inner city intersection and oncoming traffic earlier this week. Fortunately, no speeding was involved and there was no accident. You see, I was waiting to turn right and deliberately did not press the brake pedal firmly because I didn't want the start/stop sytem to turn the engine off. I was pressing the brake pedal lightly with my foot and fully expected the engine to keep running - not so! My Passat was fully stopped and the engine kept running .... until it turned itself off just as I needed to accelerate. It seemed totally illogical for it to have done this. The manual makes no mention of this whatsoever, but I think Jetfuel is right - this is a dual switch or two-stage system.
    Press the brake pedal firmly and the start/stop system turns the engine off immediately. Press the brake pedal lightly and the start/stop system seems to go into a timer mode and eventually turns the engine off. In both situations the car is completely stationary. I tried both methods today, proving my hypothesis. So, I think my reasoning makes sense and I'm wondering if other B7 TDI owners would agree with my findings?
    Moral of the story? Use the button to turn off the feature at the start of every journey!
  2. #22
    I pretty much turn mine off. I had one situation where the car didn't start and I got a message "start car manually", which meant putting it into to neutral and pressing the key again. The only time I am going to use mine is in thick stop/start traffic
  3. #23
    Jul 2011
    It's another stupid, nonsensical system that lulls us into thinking it's a smart and clever system that's saving the environment.
    However, I'm in the habit of always slotting autos into neutral whenever I pull up at lights and this cancels the auto stop function. Although I have got caught once where I pulled up at an intersection and went to take off just as the sytem switched off the engine. The car gave a good cough as it started almost before it had completey stopped. So now I turn it off as soon as I start the engine. We should be able to change this default setting to off. I'll be talking to the dealer next week about it.
  4. #24
    Jan 2009
    Melbourne Australia
    This really sounds like a pain in the Butt,
    I am not far of ordering a new B7 bassat TDi after driving my current MY09 for 2 1/2 years. In know the pain the guys with stop start are feeling. I have the same problem with the AUTO Hold function. I have to press the button every time I get in the car! ( it's not selectable in Menu in MY09 to default on). I find this a real pain in the butt. Now the new B7 has this selectable Auto hold feature but now have introduced something else to have to activate each time you get in the car,
    Think I will hold off until this is made selectable... Surely a VACOM solution is possible??
    Rotelman
    Passat MY09 125TDi DSG Wagon - Arctic Blue
    Tint,Tow,E-Tailgate, Roofbars & Cow,Fog, 12GB SDHC
    VW Bluetooth
  5. #25
    Jul 2011
    My appologies, slotting it into neutral does not cancel the auto stop feature. Must have been because the air con was running high or some other reason the times I noticed it.
    I'm sure there must be a vacom fix for this though.
  6. #26
    May 2011
    Melbourne, Victoria
    Just got back from Essendon VW and they were terrific explaining the ins and outs of the start/stop system. It's not a two-step system as I initially thought, rather all dependent on the build up of brake pressure; however, there are something like 20 different conditions that affect its functionality. For example, when I was driving home last Friday afternoon, I couldn't figure out why it wouldn't disable the engine. Turns out the slight increase in engine revs I heard was the diesel particulate filter regenerating, hence for 2-3 kms the start/stop system was disabled. Will take a while to get used to all this technical wizardry and learn to trust it!
  7. #27
    Jul 2011
    Quote Originally Posted by Buzy_Robot View Post
    ... and learn to trust it!
    that's what I'm struggling with too. I've only done 1100 k's and have noticed a number of times my engine revs changing when stopped at lights for no apparent reason (actually notice more vibration like the air con coming on, eventhough it's switched off). Don't know what it is, why would the DPF need regenerating numerous times when it's only done that low k's?
