Do you mean when reversing?
I believe that it should be able to do so - maybe the feature is not activated - try getting ur dealer to activate it via VAG-COM...
Hi,
Anyone with passat 07 is able to do this??
I tried it. It didnot work.
Any info ??
Thanks guys
Origin
Yes when reversing...
I will ask my dealer on my next service..
Did any MY07 passat able to do it ?
Thanks SCI
origin
Do you have electric seat adjustment and memory? I think you need that
Also the rear mirror selector switch has to be in the 'L' position
My passat does it sometimes. Sometimes it doesnt, weird![]()
That is the same with my auto rear wiper activation when sensor is sweeping the front glass, sometimes = works, sometimes = not...
My Passat has the same function.... as long as someone is in the passenger side!!!!!!!!!!!!!!!!!
Old Skool Passat Power Rules!!!
1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
Hi Passatfish and everyone,
No I don't have electric seat and memory. I got leather seat and factory nav but no option to change it. It has mirror adjustment option but for sync and it isn't dip function.
I will ask my dealer if that possible.
By the way I got another problem. I need everyone opinion on this if I can claim it under warranty.
My front left tyre the rubber is out a bit(like buble on the side of the rubber). I didn't bump anything on it but I saw this morning. It is coming out on the side. It is like going to explode but
no air leak still in working condition.
Do you think I can claim it or I need to replace it under my cost?
Thanks
origin
this is the information you seek from the brochure as stated above... bum
OPTION........
Electric seats with memory
Front seats with 12-way electric adjustment, driver’s seat with 3 position memory
Electrically heated and adjustable exterior mirrors, foldable with memory
Automatic kerb function when reversing, passenger’s side exterior mirror
B6 Passat Wagon No KESSY
Hi OilBurna,
mean my passat couldn't do it
Thank for your information...
cheers
Origin
