Results 1 to 10 of 11
Thread: diesel pump station
origin diesel pump station 21-03-2007, 09:27 AM
Guest Filling up with diesel 21-03-2007, 11:42 AM
origin Hi Brackie, First thank... 21-03-2007, 01:44 PM
gldgti you wont damage your car by... 21-03-2007, 09:10 PM
vw50 diesel fuel 06-11-2007, 10:05 AM
95vr6 I have tried all diesel fuels... 06-11-2007, 11:27 AM
Lams My caddy likes the high flow... 06-11-2007, 12:25 PM
The_Hawk My Mk1 used to play nice with... 06-11-2007, 01:06 PM
origin Hi All, I will try BP next... 06-11-2007, 02:24 PM
BeigeJet vw50, I'm in Melbourne and... 21-11-2007, 04:17 PM
OilBurna i work at BP - we get it from... 20-12-2007, 06:33 AM
    Feb 2007
    sydney
    diesel pump station
    Hi Guys,
    I got Passat TDI 07. This was the first time I was fill up my car. I suprised the pipe from diesel pump. It didnot go the whole way into my tank. It was only 1/4 of the pipe. I need to squees the handle gentle otherwise the diesel will throw out. I got sticker on my tank door no bio diesel. I used mobile servo.
    How do you guy fill-up your diesel car?
    Any tips or suggestion ?
    thanks
    origin
    brackie Guest
    There are two types of delivery nozzle used by servos: high volume and low volume. The high volume nozzle is for trucks and has a larger diameter. High volume pumps are usually away from the main refueling area because trucks can't get in there, while the low volume pumps are under cover.
    Low volume nozzles should go far enough into the filler neck to give no problems. There's a set of restricting fingers in the Golf's filler neck to stop the high volume nozzle going any further. I tried to take a digital of them but my camera is RS.
    Feb 2007
    sydney
    Talking
    Hi Brackie,
    First thank you for clear this to me.
    ok mobil servo near my place (opposite my house). It has only 1 diesel pump.
    it is outside. no under the roof. I asked the counter where was the diesel pump. He showed me outside the roof. No wonder It was hard to fill this diesel I need to do it slow. It took me 30mins to fill up the whole tank.
    will it cause any damage to my car? I filled up.
    Maybe I need to go to other servo that have a diesel pump under the roof.
    Regards
    origin
    Gosford Central Coast NSW
    you wont damage your car by filling it that way, BUT you might damage your enthusiasm.
    find another servo with an undercover pump, the pump will have a much smaller nozzle and you will be able to fill it without any problem.
    good luck
    aydan
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2007
    sydney nsw
    diesel fuel
    Hi Origin:
    Re diesel fuel best to check what the cetane rating is as you used mobil. The VW TDI requires at least a 51 cetane rating (similar to RON in petrol). I've check Shell, they indicate a 49 cetane; BP indicate 51. I now use BP in my 07 passat tdi. Low cetane apparently mucks up the performance etc. Also BP have a winter fuel, and in cold climates an alpine diesel.
    vw 50
    Jan 2007
    sydney
    I have tried all diesel fuels in my T5, shell, mobil, caltex, forget allthose and use Bp only, i average about 50 more k's to a tank and also cheaper. I use motormouth.com.au for fuel pricing where ever you are in sydney.
    Jan 2007
    brisbane QLD
    My caddy likes the high flow pump... can fill up in under 2 min!
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Lams View Post
    My Mk1 used to play nice with it too
    Only problem is when the only pump at the local servo is outside and it's raining
    Feb 2007
    sydney
    Hi All,
    I will try BP next time. I used Motormouth but BP the most expensive for diesel in My areas Brookvale. Thank you for your advise and support. Ole ole ole ole melb cup
    Origin
    Sep 2007
    Rowville, Victoria
    Quote Originally Posted by vw50 View Post
    Hi Origin:
    vw 50
    vw50,
    I'm in Melbourne and given that the only 2 refineries in VIV are either Shell or Mobil, where does Caltex and BP get their diesel from? I can't imagine that either of the 2 refineries would be producing a different fuel rating for BP then their own (assuming they are supplying BP and Caltex).
    Note I am tied to Caltex because of my novated lease arrangements and haven't had any concerns. So far anyway.
    Any opinions or knowledge from anyone would be greatly appreciated.
    BeigeJet
    White MY23 Tiguan 147 TDI Elegance (mine)
    White MY21 Tiguan 147 TDI Elegance (wife)
    Gone - Wheat Beige MY07 Jetta TDI manual
