Results 1 to 10 of 10
Thread: Cruise control speed adjustment
    Jan 2010
    MY10 125, standard cruise control.
    With cruise control active, briefly pressing the control lever up (to increase the set speed) increases speed to the nearest 10km/h value. For example, with the speed set to 101km/h, briefly pressing the control lever increases speed to 110km/h. If however the speed is set to 109km/h, it will still move up to 110km/h. If the lever is pressed up once again, it will increase to 120km/h.
    The same happens in reverse when decreasing the set speed.
    If I hold the lever up, it slowly increases the set speed until I release the lever.
    In the manual it says pressing the lever briefly will "increase speed in small steps". A 10km/h jump is not a small step in my book.
    Is this normal? If it is, can the amount be adjusted to say jumps of 2km/h?
    Thanks in advance, couldn't find any info on this after searching the forum.
    Cheers.
    Icelandic Grey MY10 Passat 125TDI Highline Wagon - Sunroof - RVC - Ipod
    Pull the lever towards you to move up in increments of 1 km/h.
    Deep Black MY10 R36 Sedan
    Feb 2009
    Lewiston South Austrlia
    All you have to do is flick the lever towards you and it will increase by 1 kph. If you want to reduce speed click the on/off button and it will reduce speed by 1 kph. Hope that helps pj
    Jan 2010
    Thanks, exactly what I was after!
    I was thinking the same thing as waringb. Now I know! Thanks
    2005 Mk 5 2.0L TDI Golf
    2008 Passat 125kw TDI Wagon
    Apr 2009
    Melbourne, VIC
    Don't you guys read your manuals?
    Jan 2010
    Yes I read the manual.
    No where in the cruise control section does it mention using the resume movement (pulling lever towards you) or the set speed button to raise / lower the speed by 1km/h.
    It only mentions moving the lever up / down, which results in the speed adjustments mentioned in my OP.
    Now, if there's some obscure reference in another section of the manual, I may have missed it. But I read the entire cruise control section (all 3 pages of it!) a number of times.
    Apr 2009
    Melbourne, VIC
    Sorry... It may not be in my manual. I simply put two and two together when I pulled the leaver towards me and the speed went up by one. LOL
    Quote Originally Posted by Rocket36 View Post
    Guys dont read manuals...... That is the wife's job so that she can yell and carry on afterwards.... LoL
    Mar 2009
    Perth WA
    While I've read most of the manual I find it poorly set out and not very comprehensive compared to most other manuals I've used
    2010 R36 Sedan
    2007 Audi A4 B7 Cabriolet
    1997 R33 GTR Skyline V-SPEC ,2011 Harley V-Rod Muscle
