Pull the lever towards you to move up in increments of 1 km/h.
MY10 125, standard cruise control.
With cruise control active, briefly pressing the control lever up (to increase the set speed) increases speed to the nearest 10km/h value. For example, with the speed set to 101km/h, briefly pressing the control lever increases speed to 110km/h. If however the speed is set to 109km/h, it will still move up to 110km/h. If the lever is pressed up once again, it will increase to 120km/h.
The same happens in reverse when decreasing the set speed.
If I hold the lever up, it slowly increases the set speed until I release the lever.
In the manual it says pressing the lever briefly will "increase speed in small steps". A 10km/h jump is not a small step in my book.
Is this normal? If it is, can the amount be adjusted to say jumps of 2km/h?
Thanks in advance, couldn't find any info on this after searching the forum.
Cheers.
Icelandic Grey MY10 Passat 125TDI Highline Wagon - Sunroof - RVC - Ipod
Deep Black MY10 R36 Sedan
All you have to do is flick the lever towards you and it will increase by 1 kph. If you want to reduce speed click the on/off button and it will reduce speed by 1 kph. Hope that helps pj
Thanks, exactly what I was after!
I was thinking the same thing as waringb. Now I know! Thanks
2005 Mk 5 2.0L TDI Golf
2008 Passat 125kw TDI Wagon
Don't you guys read your manuals?
Yes I read the manual.
No where in the cruise control section does it mention using the resume movement (pulling lever towards you) or the set speed button to raise / lower the speed by 1km/h.
It only mentions moving the lever up / down, which results in the speed adjustments mentioned in my OP.
Now, if there's some obscure reference in another section of the manual, I may have missed it. But I read the entire cruise control section (all 3 pages of it!) a number of times.
Sorry... It may not be in my manual. I simply put two and two together when I pulled the leaver towards me and the speed went up by one. LOL
While I've read most of the manual I find it poorly set out and not very comprehensive compared to most other manuals I've used
2010 R36 Sedan
2007 Audi A4 B7 Cabriolet
1997 R33 GTR Skyline V-SPEC ,2011 Harley V-Rod Muscle
